I have a few Questions to SimSolid.
How can I change a once created Spots (Create Spot for forces etc.) and where can I select / find them in the model tree? If several Spots laying over each other it is very difficult to select them correctly.
Is there a possibility to create Spot pattern, not Spot welds?
How can I suppress Spot areas for design studies?
How can I identify fast and easy the connection between two bodies?
Review part connections isn't that useful,
I have parts that have several thousand connections to other parts.
It would be nice if I could select only the parts I’m interested in and find only the connections between these parts.
Why can't I hide / show several assemblies at once and have to switch them one by one?
