Defining center of gravity as a constraint
I am working on an optimization problem of a blade. One of my constraints will be centre of gravity. I would like to keep the cog at 1/4 of the chord. I am having trouble in understanding how to define the upper and lower limits of cg. Should they be the coordinates? If so on whicj plane and how can I define the reference point to find out what the coordinates are?
Thank you,
Muge
Hi Muge,
Yes.
0 -
Hi Prakash,
How can I define a reference point to determine the coordinates in HyperMesh?
Thanks,
Muge
0 -
Hi Muge,
Not sure what do you mean by reference point.. Could you please explain.
0 -
Hello Prakash,
Since you said the C.G location will be based on coordinates (on x,y,z planes), I was wondering if I should select a 0,0,0 point as reference on the geometry to identify C.G coordinates based on that? Or, is there a tool that does this automatically?
Thanks,
Muge
0 -
Hi Muge,
CG will be calculated. All you have to do is to provide the upper and lower bounds.
