Hello Everyone
I have question regarding the usage of spring element. I have dogbone shaped geometry. I just want to create a spring element in the middle, so that I can use the displacement of that element in hyperview to analyse force displacement graph. The spring element stiffness should be 0, because I don't want it to have any effect on the overall result.
So I created a two nodes and in the middle a spring element should lie. I used the card image of CELAS1 and defined property PELAS. Under PELAS, I made k=0.
However, in hyperview I see no displacement happening to that point. Please tell me to resolve this issue. I have attached the screenshots and also the file. It is non-linear quasi static analysis.
Thanks in advance
