Can anyone help. I need to input experimental stress strain data in the material for Radioss Solver. I am unable to find where is the input.
You can use MAT LAW 36 for it. Make a curve with your stress strain values as input and assign the same as function in MATLAW 36. Go through the help file for more info.
For Elastic Plastic material model you can use /MAT/LAW36 where you can input the Stress-Strain function.
In Nfunct option specify the number of functions in the model and recall the same.
Please go through https://www.youtube.com/watch?v=CxM52wP3_ew&list=PLQ7KUGFuVz4u5y3SvIEIU07427-gATaG6 which shows material and property updation in RADIOSS.
