Hello Everyone
I am trying to tensile test analysis and for that I have made a dogbone shape in CATIA and then exported it to Optistruct. In the attached file, you can see that I have partioned it into several solids and then meshed it. Now I want to select the top part of the dogbone on one of the side (cubical shape) and make a rigid. So I created a node in the middle of the top part so that I can apply the loads there.Then I tried to create rigid using 'Geom>rbe3>independent node(by geom)>solids'. I selected the top solid, but it only creates node on one of the surface. I want all the nodes in that solid to be sected so that I can create the rigid.
I have attached the screenshot to make it clear and also attached the file
Would be grateful, if someone could help me out.
