Create either a tetra element or a pyramid element using the original element node list and the new node created by the script.
Look like .... homework ???
Help me to Create a node at the centroid of the element. Translate the node in the positive direction of the element normal by an amount equal to the shortest diagonal of a quad element and the shortest side of a tria element. Create either a tetra element or a pyramid element using the original element node list and the new node created by the script.
Please try this:
*createmarkpanel elems 1 'Select elements' set elem_id [hm_getmark elems 1] *clearmark elems 1 set config [hm_getentityvalue elems $elem_id config 0] # element normal set elem_normal [hm_getelementnormal $elem_id edge 1]
#node list set node_list [hm_getvalue elems id=$elem_id dataname=nodes];
# centroid set centerX [hm_getentityvalue elems $elem_id centerx 0] set centerY [hm_getentityvalue elems $elem_id centery 0] set centerZ [hm_getentityvalue elems $elem_id centerz 0]
#create node at Center *createnode $centerX $centerY $centerZ 0;
#translate node *createmark nodes 1 -1; set center_node [hm_getmark nodes 1] # create vector *vectorcreate 1 {*}$elem_normal 0;
switch $config { 104 { set Short_dia [hm_getentityvalue elems $elem_id shortestdiagonal 0] *translatemark nodes 1 1 $Short_dia; #create pyramid *createlist nodes 1 {*}$node_list $center_node *createelement 205 1 1 1
} 103 { set Short_side [hm_getentityvalue elems $elem_id shortestside 0] *translatemark nodes 1 1 $Short_side; #create tetra *createlist nodes 1 {*}$node_list $center_node *createelement 204 1 1 1
} *clearmark nodes 1 *clearlist nodes 1 #delete vector *createmark vector 1 -1; *deletemark vector 1
*nodecleartempmark
