Hello everybody. I attach a picture to better understand. Some months ago I used the 2D automesh subpanel to mesh a geometry composed by a wind tunnel, a refinement shell and an aircraft. Now, I rotate the aircraft and the refinement shell (mesh and geometry) and I want to ask you if it is possible to 'fix' the previous mesh without re-meshing all the geometry. Thank you.
