Hi everyone,
How can i get the squareroot curve of the two curves in Hypergraph ?
Thanks in advance.
Load vehicle safety tool from File pulldown: Load.Then Math option would be available under pull down menu.Select two curve with resultant option.This would help you to get the square root of two curve.Please refer attached screenshot.
