Hello everyone,
i have question regarding the laminate options in the PCOMP property card. I do not really understand the difference in the calculation when using “SMEAR” option and incase of turning the Laminate option to “OFF”. I have tried both of them and the results varry dramatically. I would appreciate it if you could briefly clarify the difference between those two options or direct me to a specific tutorial.
As a background information: i am measuring the stiffness of a carbonfibers reinforced cylinder which could be helically winded or braided. Also I am evaluating the fracture using STRN and HASHIN failure theories. The cylinder is loaded mainly under Torsion, but there are secondary bending loads as well.
usually with the Smear option the Stiffness is so much higher (50% higher) and ofcourse this affects the stresses and strains i get at the end. I'd appreciate any help.
Thanks,
Mohamed Abdelrafea
