I ran a simulation on a coil antenna with a wire port. The range of the frequency was 1 MHz to 20 MHz.
On my first simulation I set the number of frequencies to 100 with frequency increments of 191.919 kHz and these were the results:
After running a few more simulations, in attempt to make the graph "smoother" and more accurate, I set the number of frequencies to 500 with frequency increments of 38.076 kHz (this simulation had the same range of 1 MHz to 20 MHz) and these were the results:
Does anyone know why there are multiple "spikes" in my data? How can I fix this problem?
I have attached a PPT with the data collected in between these results and a copy of my model.
Thanks,
Yolanda Gonzalez
