Hi everyone,
i want to deform the seat foam but the foam deforms very bad in Hypercrash.
How can i deform the foam very well in Hypermesh or Hypercrash or anything else way?
This issue seems like related to the material parameters you have provided. If the parameters are not correct or illogical the model will behave weirdly.
Which material law you are using?.
I'm attaching a sample deck of /MAT/LAW70, which is a visco-elastic foam tabulated material.
