Hi i am running Opti struct optimization,i want to give resposnse type as static displacement, and i want to constrain give few nodes with XYZ displacement values.
Could you please help how to give this component wise constraints?
Hi VJ-JKM,
From my understanding you want to constraint the total translational DoFs on nodes to a particular displacement value. If yes, try with Total Disp filed in 'static displacement' response.
