I want to model a solid composite with MAT9ORT material.
As usual, getting all 9 material constants is pretty hard.
I want to model full unidirectional material like a pultrusion profile.
I have some material datas from compositor, which I inserted into the MAT9ORT card. (see attachment)
Optistruct stops with the error: 'Material coefficients Gij on MAT9 card produce material matrix with negative eigenvalues. This violates material stability conditions'
Does anybody know what's wrong with the material constants? What did I do wrong? Inserted them wrong? Do I need more datas? Are there some simplifications?
Thank you!
