While creating the responses in optimization for static displacement response we have to select the nodes.
please tell me what nodes are to be select.
For Displacement select nodes which are subjected to maximum displacement.
How to select the maximum displacement nodes.
During Static analysis, you can find the node subjected to maximum displacement. You can find the location/node ID of the same. Select the same node by using ID.
