Hello
Getting a problem in analysis, my 3D geometry goes into single plane during analysis.
Could you share .fem file to check setup?
please find the below attached .fem file.
@Shivang
1) there is no proper node connectivity
2) Constrain all Dofs of the Rigids.
Can you elaborate what do you mean by node connectivity?
Guide me through some video if possible.
Go to Equivalence panel (SHift+F3) select the components and click Equivalence (tolerance 0.1)
Hello Sir
I have done both the things you told me but getting the same problem.
Tell what to do?
Ignore my previous reply as on trying more I got to my conclusion.
Thanks to @Prakash Pagadala
