Hey All,
Can someone please tell me what am i missing here. Hex Model with Contacts & Properties defined
*** ERROR 14: Missing element # 449 referenced by SURF # 8.
Vaman
Dear Vaman,
Can you share your model files & information regarding your simulation ?
Once you provide the same. will revert you back over the same.
This forum is open for everyone, so kindly do not share your model file over forum .Kindly use below provided Drop-box link to share the model for secure file transfer.
Thank You for the response @Praniket. Relevant file is shared with you and @Prakash Pagadala
