Error message property
I am discovering the OptiStruct solver and am doing a normal beam bending analyse, which does not work. Following error message comes:
ERROR 14: Missing property # 1 referenced by CHEXA # 671
I've already searched for the problem, but was not able to find it. The property is created with the card image 'PSOLID' and associated to the component. I've also tried the card image PSHELL, but this did not work neither.
The mesh is created with the 2D automesh and than the 3D element offset.
Can someone help me to find a solution?
Many thanks!
Forget to remove 3D mesh?
0 -
If you want to analyze the beam with solid elements, retain only solid elements and use PSOLID card and delete the 2D elements.
0 -
Sorry, I mean 2D mesh
0 -
Thank you it worked!
