how to restart a run when it is stopped before completion?
Hey Arun,
copy your file x_0001.rad file
rename it to x_0002.rad replace /1/ by /2/ and save it as mentioned in figure below.
after that
open radioss and call that file with 0002.rad and run the simulation
please see this image
regards,
Ganesh M.
Dear Arun,
use same anology in acusolve.
Dear all,
correct if i'm wrong.
Ganesh m.
Dear Ganesh,
Thank You, I will try this approach also and let you know.
Just few minutes back, I found an approach to restart the run, but I'm not clear with the options used in. But it is working.
Warm Regards,
Arun Prasanth
In the launch AcuSolve Window, there are various options to use restart. See screenshot.
In case nodal outputs were not saved, you might get an error with restart. Let me know if you face any issue and post a screenshot of your run folder and upload .Log + .inp files.
