Hi there,
Created a fairly complicated part in Autodesk Inventor over the past couple of weeks. It looks this way as a result of a topology optimization run in Optistruct a while back.
(attached is an image of the part, as taken in Inventor)
However, now that I have drawn the part in Inventor, I am trying to bring it back into Hyperworks to analyze the part. However I cannot use the volume tetrameshing on this part. The imported IGS file seems to have gaps where there shouldn't be, and there are red lines appearing on the model when I try to do the tetrameshing.
I should mention that I did do a lot of filleting of sharp edges prior to bringing the part into Hypermesh.
Any thoughts or suggestions?
