Error id 760
Dear Sir,
As we are facing issue in error id 760 continuously,
we have updated element types,
we have checked material and properties and recreated it,
we have deleted contacts and created it again carefully..
but still this error is there..
can you check our model and let us know where we are doing mistakes...also the angular velocity is not working properly..
here by I have attached our bus model FRP structure ...find the attachment please ,and let us know as soon as possible...
Prasad Sirsewad
This error is happening due to the Type 2 contact in the model. Type 2 is a kinematic condition that connects a set of slave nodes to a master surface and I don't think it's required here.
For the Type 7 interface many penetrations are there and please clear them before running.
0 -
Dear George,
I have once again checked my model, deleted type 2 contacts, removed all penetration and intersection, there is no any free 1D's , no dependency, no free edges, no element failed, material and properties also assigned again..
but still error 760 is their..?
I have attached the files of corrected model as you said, please have a look and let me know where we are doing mistakes..
0 -
This fie runs fine in 2017 version. I strongly recommend you to upgrade to the latest HyperWorks version.
Meanwhile for the time being you can try with the attached file which runs fine in 13 version.
0 -
Sir will you please share the link for 2017 version & the procedure for upgrade ? so we can upgrade it..
Regrds,
Prasad.
