there is on Hypermesh a command similar LINK180 on Ansys?
regards
Hi @jugerman
Yes, please use ROD elements in 1D page.
Thanks @Prakash Pagadala I wanna set up the ROD element as a rope initially non tense: it is connected an a sistem that increase strength over time. Initially the ROD does not resist but when it get to the length granted, it can not have more stretching. After i calculate the axial FORCE exerted.
Regards
