While doing FRF analysis Optistruct is calculating Residual vectors. can you kindly explain the importance of residual vectors.
Please refer attached screenshot and pdf from online help.
Thanks for your reply.
I have one more question.
In your attachment it is mentioned as Residual vector calculates the displacement vectors of a static analysis based on dynamic loading. In FRA how static analysis is calculated and how it improves the results.
Thanks in advance.
Please refer attached screenshot from help.
