Incus Malleus Joint - Contact and Non Convergent Issues
Ossen
Ossen Altair Community Member
im new in Optistruct and doing a project given from my docent. The project is about IMJoint simulation to see how it work with different parameters ligaments. In here, CGAP with preload will be use as ligament and those ligaments (CGAP) will pull the Incus to Malleus (Malleus is in BC condition) to make a contact. but when i run the simulation, i encounter with Non Convergent Issue
  *** ERROR # 941 ***
  NON-CONVERGENT NONLINEAR ITERATIONS FOR SUBCASE 1
  Suggestions:
  ANALYSIS COMPLETED.
from the Out. file, after 10 iterations it cant not be convergent. and i checked the hyperview, the load factor up to 9, the Incus is being push away from Malleus.
So i tried to change the CGAP to Flip and from the result there is no Non-Convergent error, but the Incus is still push away from Malleus.
Can somebody help me?
Thanks in advance
  • FaroukM
    FaroukM Altair Community Member
    edited April 2020
    Can you please share the *fem file because I have 2017 version.
  • Ossen
    edited April 2020
    hi..
    thx for the reply..
  • FaroukM
    edited April 2020
    hi..
    thx for the reply..
    Thanks. I add some modification to fix the convergence of the model (please see file below).
    Can you please explain the boundary condition. I want to verify the results ...
  • Ossen
    edited April 2020
    Hi Mr. Farouk;
    Thx for helping me. i will check the model.
    from what i get the docent told me, the Malleus (green model) is in stationary condition and the ligaments (CGAP with preload) will be pull the Incus (red model) to Malleus. after Malleus and Incus make a contact which i think will be a Slide effect, then i will give a force (in various position) to Malleus so i can see how the ligaments react to the force.
    and somehow the docent said it is small displacement, but from what i read in a paper about IMJoint, it needs large displacement and CGAP is not support large displacement. But thx again Mr. Farouk.
    edit:
    i checked the model, but the Incus is push away from Malleus. ill try change cgap to flip.
  • FaroukM
    edited April 2020
    Hi Mr. Farouk;
    You welcome.
    edit:
    Yeah this is why I asked you. Thanks for the explanation ;)/emoticons/default_wink.png' srcset='/emoticons/wink@2x.png 2x' title=';)' width='20' />
  • Ossen
    edited May 2020
    Hi Mr. Farouk,
    i tried to make the contact but its not working.. i had been trying it like a week and cant find a solution.
    can u please help me?
    thanks
  • FaroukM
    edited May 2020
    Hi Mr. Farouk,
    thanks
    Hi Ossen,
    I ran your model but I don't understand what's the problem ? Can you please more :)
    Best regards,
  • Ossen
    edited May 2020
    Hi, Mr Farouk,
    thanks for the fast response. i think when the 2 bones make a contact, they should be have slide effect. but from my model the bone is deform and dont have slide effect. i tried to increase the youngs modulus but i got the same result. or maybe im wrong?
  • FaroukM
    edited May 2020
    You can try to activate the tangential component of the contact force by adding friction in CGAP property ...
  • Ossen
    edited May 2020
    Hi Mr. Farouk,
    thx for your help. the problem is solved :)/emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20' />
    i got a new assignment, still same model but new mesh and with solid property. I try to make two load steps, which the 2nd load step begin from the end of the 1st load step.
    in the 2nd load Step i use CNTNLSUB with SCID from 1st load step. But somehow the result is the 2nd load step begin from the start of the 1st load step.
    i read the manual that said CNTNLSUB doesnt support non-linear quasi static. and i read from forum, if we change spc D to F it maybe work. i tried lookin the FEM file with text editor, cant find it. maybe im doing it wrong. Can u please help me?
