Induction Motor
Benjamin Vallet_22463
Altair Employee
edited July 12 in Altair HyperWorks
The studied device, represented in the figure, is a 4 pair poles induction motor, 3-phases star connected, characterized by:
• rated – load power, Pn = 3 kW
• rated source voltage, Un= 400 V (line to line value)
• rated source frequency, fn = 50 Hz
Analysis
<!> Working in progress <!>
Results
Example access
All files corresponding to this example are accessible with this link:
  • For SimLab 2024.1: <!> Working in progress <!>
Step to follow:
  • to follow the example step by step, the corresponding files are in "Example_name_StepByStep" folder containing:
    • Input folder: contains initial *.slb databases an other files needed to be able to play manually  the tutorial by following the step by step document
    • Output folder: empty (contains the obtained results after to play the tutorial)
    • Tutorial folder: contains the document describing the example step by step
  • to play the tutorial by scripts, the corresponding files are in "Example_name_PlayScripts" folder containing :
    • Initial folder: contains initial *.slb databases an other files needed to be able to run scripts of  the tutorial
    • Output folder: empty (contains the obtained results after to play scripts of the tutorial)
    • ScriptsTutorial folder: contains script files to be able to play each analysis
