Example models comparing Lagrangian, Eulerian, ALE, and CEL formulations used in Radioss for FSI
NolanMcP
NolanMcP
Altair Employee
edited April 2024 in Altair HyperWorks
The purpose of this article is to provide examples models that help introduce Lagrangian, Eulerian, ALE, and CEL modelling techniques that can be used in Radioss for Fluid Structure Interaction.
The attached zip file contains models and results of the simulation of a high explosive charge detonating against a steel plate. The different formulations used are :
  1. Lagrange formulation
  2. Euler formulation
  3. ALE formulation
  4. CEL formulation
A session file (.mvw) is provided to compare all four models using HyperView.
