Cannot Connect to the License Server
Lloyd Lualhati
Lloyd Lualhati
Altair Employee
edited April 2024 in Altair RapidMiner
Condition:
When trying to connect Monarch to the License Server., the error message "Cannot connect to the License Server at http://xxxx11110029:51515 this may occur for the following reasons" is displayed.
Cause:
Unknown
Remedy:
Restart the License Server services.
1.) Go to Windows Start menu > Administrative Tools > Services
2.) Locate License Service in the list.
3.) Verify the value in the Status column. If License Service is not started, right-click License Service and select Start.
4.) If the License Service is already started, right-click and select restart.
5.) Relaunch Monarch and try to connect to the License Server.
