Compose script to read and write all outputs of plotting file to new .ABF file
Sebastian_Karp
Sebastian_Karp
Altair Employee
edited May 2024 in Altair Exchange
Overview
This Compose script will scan a plotting result file and write all outputs to a new .ABF-file.
Pre-Requisite
Open the .OML-script in Compose and edit lines 4 and 7 to reference the used original plotting result file, and the target output ABF file.
Usage/Installation Instructions
RUN the OML-script. A new .ABF-file will be created in the set folder.
Post-Requisite
Original outputs:
ABF outputs
