Interested in designing tracks within a multibody framework? MotionView provides a feature known as the 'Track Builder' that empowers you to construct rolling systems, adjust the components entwined with these systems, and engage with a soft soil environment. This video series will guide you through the process of building a fully operational track system that can seamlessly interact with a soft soil environment.
