This exercise will focus on setting up a BAJA car frame model for the following Static Structural Analyses (note the captions at the bottom of the video)
Modal Analysis
Front, Side and Rear Impact
Bump Analysis
Torsional and Rollover Analysis
Video by Dhanashree Jadhav
