Monarch Learning Series 2023 Exercise 9 - AP Expense Report Analysis
Baba_Majekodunmi_703
Altair Employee
Exercise Info
- Application (Classic vs Data Prep Studio): Data Prep Studio
- Level of Difficulty (Beginner, Intermediate, Advanced): Beginner
- Skills/Features Tested: Join, Analyze, Formula Field, Lookup Field, RegexIsMatch Formula
- Systems of Record: Not Applicable
- Estimated Time to Solve: 10 mins
- Exercise files required are attached in the Zip File Below;
- Expense Report, 2016-12.pdf
- Expense Report, 2017-01.pdf
- Expense Report, 2017-02.pdf
- Currency Rate Pairs.xlsx
Exercise Overview
You are an Accounts Payable Accountant at a Software Company and you need to analyze 3 months worth of expense reports to answer the following questions:
- What is the Total Expense in USD for the 3 Expense Reports (2016-12, 2017-01, 2017-02)? (HINT: You will need to convert any expenses not in USD by using the Currency Rate Pair.xlsx file and creating Formula field for the USD rate for the non-USD expenses)
- Who are the Top 3 Employees that spent the most on any Expense that contains
- "Travel"
- "Taxi"
- "Airfare"
- "Airline Fees"
- "Hotel"?
- "Lunch"
- "Breakfast"
- "Dinner"?
Exercise Answer
Not sure you got the correct answer? No problem. Watch the video below for a demonstration of this exercise from start to finish.
0
