Import ETABS® model data: support locations, reaction loads, load cases, and load combinations.
This step-by-step tutorial shows how to bring in the data after performing an ETABS® analysis. After all the data is imported, run a code-check and analysis to get a pass-fail status as well as all the different code-check results for the foundation model.
S-FOUNDATION is developed and supported by S-FRAME Software.
