Reduce concrete design time by evaluating multiple reinforced concrete beams, walls, and columns in one operation. S-CONCRETE Batch Processing designs and generates a single design report that includes the results for all sections in the batch process. This tutorial walks through the steps needed in a concrete design batch process:
