This concrete wall design video expands on the S-CONCRETE overview video and describes how to model and design reinforced concrete walls. Concrete wall design supports multiple regional concrete design codes. Easily import reactions from S-FRAME Analysis or other 3rd party structural analysis solutions. We work through an example of a failing wall to demonstrate how to design and code check to satisfy code requirements. Users can manually or automatically design to user-defined constraints, view results, and export reports.
