Installing Altair License Manager Version 2025.0 on Windows
Sasi_Mrudula_Gudem1
Sasi_Mrudula_Gudem1
Altair Employee
edited January 15 in Altair HyperWorks
Download the Altair License Manager from Marketplace on Altair One. The License Manager Tab would be accessible for all the applications for which you have a license.
 Save the executable in a local drive on the Server on which it is to be installed.
Once done, refer to the video showing the steps to install Altair License Manager.
Setting Up Environment Variables:
As shown in the video,
Have the following environment variables set exactly as below under system variables.
VARIABLE NAME:  ALTAIR_LICENSE_PATH
VARIABLE VALUE: 6200@SERVERNAME OR IP Address
 P.S: Server name or IP address refers to the license server machine’s name or IP address.
Make sure there are no spelling mistakes in the variable name or server name and are case sensitive.
The environment variables are to be set only under the system variables.
Please Note: Please make sure there is only one *.dat  or *.lic (license file) in the installation directory.
Welcome!
Welcome!
