In this webinar, We present about antenna placement and RF system performance in real platforms and scenarios, including co-site interference effects. We will cover model clean-up and meshing, selection of the right solver depending on accuracy, HPC resources, and antenna and RF system analysis and optimization including co-site interference. We will also demonstrate the solution in action followed by an open discussion.
