Please Download the Quick Reference Sheet attached that displays an example of how you can capture data in seconds and build a reusable trapping Models/Workspaces utilizing Altair Monarch.
Altair makes data extraction from PDF, text, or legacy reports visual and straight-forward.
When first bringing in the Report/File into Monarch, it will launch into REPORT DESIGN. You are presented with a visual rendering of the Report which provides one the opportunity to determine the data to extract/capture. As one is selecting the Fields, a PREVIEW of the Extracted Data within a Table Format are displayed in the lower half of the Report Design Window while the visual rendering of the report is viewable in the upper half.
TRAP LINE: this is where one will set the Pattern to identify the line(s) for the Template they are creating.
SAMPLE TEXT: A reference used to build the 'trap' and select the fields looking to extract from the file/report
TRAPPING TEMPLATE Types:
GROUP FOOTER: Template used to extract data BELOW the Detail Template.
Notes:
