You can download all Monarch exercise files here: Monarch Sample Files for Exercises
You are a Tax Accountant and you need to apply the appropriate tax rates to sales orders on the Classic.pdf file, so you can file taxes with the appropriate states. You need to perform the following tasks
*Hint: You'll need to use Monarch Classic for this part.
Not sure you got the correct answer? No problem. Watch the video below for a demonstration of this exercise from start to finish.
