A. Y. Feoktistov, I. I. Blekhman, K. S. Yakimova, L. I. Blekhman, V. A. Arsentyev, V. B. Vasilkov
Ore and Metals Publishing House
Mineral Processing
Possibility of loose small-grain material size classification based on the effect of vibratory segregation in combination with material vibrotransport is shown. A screenless continuously working apparatus is proposed, providing for efficient separation at small separation sizes. The experimental results qualitatively agree with results of computer-modeling, performed with application of discrete components technique.
classification, computer-modeling, experiment, loose material, segregation, Vibration
