Simulation Files and tutorial PDF download link
EDEM Tutorial 18 - Lift and Drag Models.zip
EDEM Lift and Drag Models tutorial Overview
This tutorial describes how to create a one-way coupled particle-fluid model using the in-built Particle Body Force drag and lift models.
The main focus is on:
- Importing Field Data via the Field Data Manager.
- Using the in-built lift models.
- Using the in-built drag models.
- Using the Steady Velocity Flow feature.
This tutorial is based on the AcuSolve tutorial 'ACU-T: 6101 Particle Separation in a Windshifter using AcuSolve - EDEM Unidirectional Coupling' for more information on creation of the flow field used in this tutorial please review the AcuSolve tutorial.
Tutorial Level
Beginner
Model Overview
Particle separation in a Windshifter.
Duration
Setup - 10 min
Simulation - 5 min
Analysis - 5 min
For further EDEM learning material please see the following links for tutorials , e-learning, training and How-To videos:
For more information about custom drag models pleas see:
And for further information and latest updates please see the Altair EDEM Community page:
