EDEM Tutorial 17: Polyhedral Particles
Stephen Cole
Stephen Cole
Altair Employee
edited September 2022 in Altair HyperWorks
Skill Level
Beginner
Tutorial Overview
In this tutorial, you will learn how to import a polyhedral particle shape to EDEM and run a capsule simulation.
The main focus of this tutorial is on:
  1. Importing a polyhedral particle shape
  2. Setting up the required equipment
  3. Running and post-processing the polyhedral particle simulation
Duration
Setup - 15min
Simulation - 5min (Note this simulation requires supported NVIDIA GPU)
Analysis - 5min
Welcome!
Welcome!
