EDEM Tutorial 13: Block Factory
Stephen Cole
Stephen Cole
Altair Employee
edited April 2022 in Altair HyperWorks
Skill Level
Intermediate
Tutorial Overview
This tutorial explains how to generate large particle beds using the block factory feature, which duplicates small modular particle blocks and assembles them together, forming a larger bed.
The main focus of this tutorial is on:
  • Creating a small particle bed using the Soils Starter Pack
  • Using the block factory feature to generate a large particle bed following a simple procedure.
  • Applying templates and textures to particles.
Duration
Setup - 20min
Simulation - 15min
Analysis - 5min
Welcome!
Welcome!
