Presentation by Livio Mariano, Technical Specialist, Math & Systems at Altair.
Using a realistic example of calculating home heating efficiency, learn how to leverage the interoperability between Compose and Excel to get the best of both worlds: Excel for the front-end (i.e., GUI generation) and back-end (i.e., results analysis) with Compose for the middle (i.e., modeling and simulating complex systems).
