By default, quantities displayed on a path are plotted versus ABS_CURV of the path. In order to plot quantity versus other coordinates, you need to follow the procedure below:
1 | In the New 2D curve (path) window, select the path and the quantity to display. Then, click again on f() and go in the tab XYZ. |
2 | Select the coordinate you want and click on Ok to add it on the plot. Display the curves. |
3 | Once the curves are displayed, go in the tab Axis and replace ABS_CURV by the coordinate you want. |
