The “Frozen permeability” in Flux is a specific feature that allows freezing the permeability from a first computation. The frozen permeability can be used in a second computation with different values of current, or without magnet for instance.
To activate the frozen permeability, you have to follow the procedure below:
1 | 1 Solve the first case |
2 | Select Parameter/Quantity -> Export quantity-> Export spatial quantity and formula starting from different types of supports Here is an example how to fill in the fields:
3 | Click on the OK button (normally a specific *.DEX file is created in the working directory) |
4 | Close the current project |
5 | Open the 2nd Flux project |
6 | Select Parameter/Quantity -> Import parameter and quantity -> New (constant) tabulated spatial quantity by importation Here is an example how to fill in the fields:
7 | Click on the OK button |
8 | Create a new magnetic material (select Physics->Material->New)
9 | Modify the property of one region in order to use this new material Note: you have to repeat steps 8 and 9 for each region with frozen permeability |
10 | Solve the 2nd project and analyze the results |
