Basics of Compound Blocks : Dialog Constants, Pins, Levels, & Built in Variables
In this video you will learn how to:
Create compound blocks to add levels to your model
Navigate through your model
Add/remove compound block connector pins
Use compound block dialog constants and dialog windows
Access and use built in variables
