| Computation |
| F5 | Propagation: compute all |
| Alt+F5 | Propagation: compute selected |
| Ctrl+F5 | Propagation: compute modified |
| F6 | Propagation including mobile station: compute all |
| Alt+F6 | Propagation including mobile station: compute selected |
| Shift+F6 | Propagation post-processing including Tx and Rx |
| F7 | Network simulation: compute all |
| Alt+F7 | Network simulation: compute selected |
| File |
| Ctrl+N | New project |
| Ctrl+O | Open project |
| Ctrl+Shift+O | Open result |
| Ctrl+D | Open database |
| Ctrl+S | Save project |
| Alt+Ctrl+S | Save project as |
| Ctrl+Shift+S | Save result |
| Alt+Ctrl+Shift+S | Save result as |
| Ctrl+B | Export bitmap |
| Alt+Ctrl+X | Export ASCII (all) |
| Alt+Ctrl+O | Import data |
| Alt+Ctrl+F4 | Close project |
| Alt+F4 | Exit ProMan |
| Display |
| Ctrl+R | Reset window |
| Ctrl+Z | Zoom window |
| Shift+Num + | Zoom in |
| Shift+Num - | Zoom out |
| Shift+Num * | Former zoom window |
| Alt+M | Move window |
| Ctrl+Shift+Num 8 | Move window North by 20% |
| Ctrl+Shift+Num 2 | Move window South by 20% |
| Ctrl+Shift+Num 6 | Move window East by 20% |
| Ctrl+Shift+Num 4 | Move window West by 20% |
| Ctrl+Num 8 | Move window North by 5% |
| Ctrl+Num 2 | Move window South by 5% |
| Ctrl+Num 6 | Move window East by 5% |
| Ctrl+Num 4 | Move window West by 5% |
| Alt+Num 8 | North |
| Alt+Num 2 | South |
| Alt+Num 6 | East |
| Alt+Num 4 | West |
| Ctrl+3 | 3D display |
| F8 | Presentation plot |
| Ctrl+W | Show all propagation paths for pixel on mouse move |
| Ctrl+U | Show all propagation paths for pixel individually |
| Ctrl+K | Delete all propagation paths on display |
| Alt+Ctrl+I | Display Channel Impulse Response (CIR) |
| Spacebar | Toggle selection of selected rays on the Propagation Paths dialog. |
| Edit |
| Ctrl+E | Edit data |
| Ctrl+F | Change-edit value |
| Alt+Ctrl+E | Increase numbers of columns and lines |
| Alt+Ctrl+R | Change resolution |
| Alt+1 | Add data value (file, linear) |
| Alt+2 | Add data value (file, delog, incoherent) |
| Alt+Shift+2 | Add data value (file, delog, coherent) |
| Alt+3 | Add data constant (linear) |
| Alt+4 | Subtract data value (file, linear) |
| Alt+5 | Subtract data value (file, delog, incoherent) |
| Alt+Shift+5 | Subtract data value (file, delog, coherent) |
| Alt+6 | Subtract data constant (linear) |
| Alt+7 | Combine data: maximum value |
| Alt+8 | Combine data: mean value |
| Alt+9 | Combine data: minimum value |
| Alt+Ctrl+E | Modify geometry of data: increase number of columns and lines |
| Alt+Ctrl+R | Modify geometry of data: Change resolution |
| Alt+Ctrl+F | Filter data in area |
| Alt+Ctrl+M | Smooth data in area |
| Alt+C | Change legend (continuous/discrete) |
| Alt+F3 | Edit material properties |
| Analysis |
| Alt+Ctrl+I | Channel Impulse Response |
| Alt+Ctrl+L | Display values along a line: Draw line with mouse |
| Alt+Ctrl+T | Display values along a line (from transmitter): Draw line with mouse |
| Alt+Ctrl+A | Save values in ASCII-file |
| Ctrl+G | Compute distance |
| Ctrl+I | Information |
| Settings |
| Shift+F4 | Open global settings |
| F4 | Open local settings |
| Shift+F8 | Load local settings |
| Ctrl+F8 | Save local settings |
| Ctrl+Shift+F8 | Save local settings as |
| Alt+F8 | Copy local settings to all documents |
| Window |
| Ctrl+F4 | Close window |
| Alt+F10 | Cascade windows |
| Alt+F11 | Tile windows (horizontally) |
| Alt+Ctrl+F11 | Tile windows (vertically) |
| Alt+F12 | Arrange symbols |
| General |
| F1 | Open the WinProp User Guide |
| At+F1 | About ProMan |
