Mr.
2»
Answers
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited November 2017
    Hi Prakash
    I tried. It doesn't work.
  • Altair Forum User
    Altair Forum User
    Altair Employee
    Never mind. I figured it out
    thanks
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited November 2020
    Hi,
    In the model file the connectivity between elements was not maintained and so the elements were 'flying' away.
    Please try with the attached file, where the connectivity is maintained.
  • Altair Forum User
    Altair Forum User
    Altair Employee
    Thanks George
    The model below works fine. But strangely the values are not what I would expect. It is a simple model of a plate with a hole. Shouldn't the stress be maximnal at the hole itself?
    However, the results shows otherwise. Please have a look
  • Altair Forum User
    Altair Forum User
    Altair Employee
    Please reply as soon as possible
  • Altair Forum User
    Altair Forum User
    Altair Employee
    Hi Novak,
    Yes that is because there are nodes which are not connected around the hole which is not correct.
    I would suggest to manually check nodes connecting hole and plate and fix them before you run the analysis.
    I have attached results after equivalencing nodes to tolerance 0.1
  • Altair Forum User
    Altair Forum User
    Altair Employee
    This one looks reasonable.
  • Altair Forum User
    Altair Forum User
    Altair Employee
    Thanks Prakash
    I do manage to get the stresses as shown in the first screenshot. But how to get the stresses like 2nd screenshot?
    Sincerely
  • Altair Forum User
    Altair Forum User
    Altair Employee
    Also, please share the file in which you got the result like the second screenshot
    Thanks
  • Altair Forum User
    Altair Forum User
    Altair Employee
    Thanks a lot Prakash
    Appreciate your help really
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited December 2017
    Hey Prakash
    Can I ask a question regarding solidthinking COMPOSE here?
  • Altair Forum User
    Altair Forum User
    Altair Employee
    Hi @Novak
    I am not at all familiar with solidThinking Compose. Please post your question http://forum.altairhyperworks.com/index.php?/forum/71-solidthinking-compose/
    Experts in Compose will reply to as soon as possible.  :)/emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20'>
  • Altair Forum User
    Altair Forum User
    Altair Employee
    Hi Prakash
    They did help. Thanks for the info
  • Altair Forum User
    Altair Forum User
    Altair Employee
    Hello
    I have a question regarding meshing and some question related to MotionSolve for my model. But I can't the share the model here. Could you please give me your private email address so that I can send the model?
    Thanks
  • Altair Forum User
    Altair Forum User
    Altair Employee
    Hi,
    Please use the file transfer link in my signature to share model files.
  • Altair Forum User
    Altair Forum User
    Altair Employee
    Hi Prakash
    I made a small mistake in last message. Disc is supposed to be fixed. It is the 'sheet' which is suppose to rotate and make cylinder go up and down
    Thanks
    Sincerely
  • Altair Forum User
    Altair Forum User
    Altair Employee
  • Altair Forum User
    Altair Forum User
    Altair Employee
    Hi Prakash
    I just have general question regarding Motionsolve.
    If i import a geometry 'A' from hypermesh to Motionsolve and then I add joints, contacts and rest of the stuff to it. If I later find out that there is a small meshing error in geometry 'A' and I rectify it. Do I have to create all joints, contacts and rest of the stuff again in Motionsolve or is there a way to modify it and still have joints and contacts created earlier?
    Thanks
    Sincerely
  • Altair Forum User
    Altair Forum User
    Altair Employee
    Hi @Novak
    If you change the mesh or anything, you need to create another graphics H3d, etc.. though the mass and inertia may not change.
    In my opinion it is good to import the modified file back in MV and recreate everything to avoid sudden surprises.
Welcome!
Welcome!
