Altair RISE
Nominate Yourself Now!
Error of "Uniform" block
User: "Tom_abc"
Altair Community Member
Updated by Tom_abc
I opened a Vissim file which can run successfully before. However, this time when I opened it, an error occurred (see Fig below). It said that "Uniform.7860(Compound) is missing output tab 1". And I cannot click on that block called "uniform". I think that block was inteded to generate some random numbers, and it was a built-in block. Why does this error happen? Is it because this built-in function no longer available? How can I fix it to run the model?
1 - 5 of 51
    User: "Andrei Urtmintsev"
    Altair Employee
    Updated by Andrei Urtmintsev
    Embed does have a uniform block under Blocks > Random Generator.
    Reading your description, my first thought is that the diagram i.e. .vsm file can be corrupt. Is it possible to share your diagram (.vsm) here?
    User: "Tom_abc"
    OP
    Updated by Tom_abc
    Thanks Andrei! I'm afraid that the ".vsm" file cannot be uploaded. I will check the program to replace them by the "Blocks > Random Generator"
    Altair Employee
    I understand. Can you at least copy-paste and save the diagram excerpt from the picture?
    User: "Tom_abc"
    OP
    Updated by Tom_abc
    Hi Andrei, here I attached those blocks shown in the picture. What is interesting is that at the original vsm file, I cannot went into the "uniform" block (i.e., right-click that block and then nothing happened). However, when I pasted those blocks into this new vsm file, that "uniform" block seems become just a "compound" with nothing inside it (i.e., I can right-click on it but nothing existed inside it).
    Altair Employee
    I can see inside something strange what I do not expect from a compound block.
    If you open your small file in Embed, then remove the compound block, then create a brand new compound block and name it "uniform". Save the diagram with a different name. If you open .vsm file in any text editor, even Notepad, and scroll to near bottom, you'll see something
    N.NUMBER="Compound" and so on
    Compare yours and freshly saved. I have no idea how to get where your original diagram was.
