analysis with the Force on MPC (Multiple point contraint)
Hi,
i've analized the Bracket at first with Forces direktly on nodes in the body. Everything was done good and i could see strain and stress in Hyperview. Then i've made a new node at the center of tube and connected it (as independent node) with all nodes in the tube (as dependent node). After that i've set a constant Force on the independent Node.But according to picture ''MPC_Hyperview'' nothing (displacement,stress, etc.) ist presented.
Where is my mistake ? as far as i know we use Indpt-node to distribute the force homogen/equal on dpt-nodes.
Hi tinh,
Thanks for your Answer. Yes, i've activated dof1-dof6 (RBE2 22560 5031 123456). For each element ist written such error ''USER FATAL MESSAGE 9994 (BULKPM), CTETRA with EID=11950 near line 3417 '' in *.bdf data. additionally theres isn't any amount of Displacement, Stress and Strain in the data.
because of huge amount of element i didn't make RBE2 (Indpt-node and their dpt-node) with command 1D -> rigids , but with a special matlab programm. this programm makes MPCs on a Body with *.bdf Format. The Programm hasn't problem. but it makes contact lines between Indp-node and dpt-node as second component. Therefore i've set for that material and Property too.
''misc1'' is Indpt-node and their dpt-node.
Hi Mac
did you try increasing the force?
and please confirm that you activated dof1-dof6 when you created RBE2
