Altair RISE
Nominate Yourself Now!
connecting nodes of different mesh size
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
I have 3 rectangular solids of dimensions 250*52*1.5 ,250*6*1.5 and 250*2*1.5 mm respectively. I need a refinement of 2.5,1.25 and .5 respectively. But when I am using solid map option for meshing solids, though I am getting the refinement as needed, nodes of meshes at the shared edges are not getting connected as shown in the figure attached. so how can i give transition edges at the shared boundaries so that nodes are connected properly. ?? Thanks
<?xml version="1.0" encoding="UTF-8"?>post-32725-0-58392400-1409219885_thumb.j
1 - 12 of 121
    User: "Rahul_P1"
    Altair Employee
    Updated by Rahul_P1
    When the node count is different you can use 'ends only' with just 'elements to drag' and the 'destination surface'.
    As a side note, A cube for instance with say 5 elements in one side and 10 elements in its opposite side, cannot be mapped with solid elements generally, this is physically impossible while maintaining connectivity !
    Altair Employee
    OP
    thanks rahul. I used 2-d automesh for .5mm element size(hex mesh) in one surface and 2.5mm in a parallel surface. Is their any option to connect these two surface meshed using tetra or any other elements other than hex.?? when using 'ends only' options, element type is not being asked!!!!
    User: "Rahul_P1"
    Altair Employee
    Updated by Rahul_P1
    vbjohn21
    Yes, you can use tetramesh.
    For a simple review, just go to 3d tetramesh, volume tetra, with match existing mesh option checked.
    you can then later , do a tool > edges > preview equivalence and equivalence.
    Altair Employee
    OP
    I tried as u said with the 'match existing mesh checked' in 3-d tetra mesh. but still nodes of solids on both sides did not connect to middle one as shown in figure attached.  I guess may be I did some mistakes in the initial stage. These are the steps I did so far. Please check if something went wrong
    1)imported 3 solids into hypermesh
    2)used geomtery-solids command created a fine solid
    3)3-d- solidmap -one volume- meshed two of the end solids with 5 and .5mm
    4)did 3d-tetra-volumetetra to mesh middle surface
    <?xml version="1.0" encoding="UTF-8"?>post-32725-0-21450300-1409232779_thumb.j
    Altair Employee
    OP
    Hi,
    Here is my example, see screenshot.
    And here is my model HM: https://dl.dropboxusercontent.com/u/7959896/HW/plate.hm
    Maybe this can give you some idea.
    HTH,
    <?xml version="1.0" encoding="UTF-8"?>post-889-0-22753400-1409234955_thumb.png
    Altair Employee
    OP
    Thank you Ngyugen. The picture what you showed is  exactly what I was trying to reach. But I am not been able to reach there so far. And Unfortunately I am not able to open the file which you sent, it is showing 'file is not backwardly compatible with this version'. My version is 11.0. Could you please tell me if there is any mistakes in the steps i mentioned in last reply. (P.s here out of 3 solids middle solid I have used for getting a transition).
    Thanks
    Altair Employee
    OP
    Altair Employee
    OP
    Thanks Nguyen. Now I am able to view the model. As of now i can just see the  components.  Is there any option in hypermesh to see the various steps involved in creating this? If not available could you brief the steps involved. Sorry for shooting so many questions.
    Altair Employee
    OP
    With some meshing experiences, you can make the same mesh by following my example.
    Maybe I'll make a small tutorial later, when I have some free time.
    Altair Employee
    OP
    Hello,
    I am rather new to the entire FEA area and I need to have a fine mesh in the middle of the volume. Looking at these posts, I see that what you have,
    on this image  ,  is what I need.
    Links above are not availables now, so, could it be the possibility that you pass me an example with few indications?. That would be so great for me.
    Thanks in advance for your support
    User: "Rahul Rajan_21763"
    New Altair Community Member
    Updated by Rahul Rajan_21763
    You can try tetramesh panel with refinement box.Also if requirement is to create tetrahedral element then you could try Altair SimLab for meshing.
    Altair Employee
    OP
    Many thaks Rahul, I will try and see if I am able to do it. I will come back.
